13
This discussion topic has been answered Discussion topic: Need a PIN code to download
This message was authored by: ShorehamNick
Before I can download anything on Sky go, it says I need to set up a device pin, despite following the instructions there does not appear to be ant option to do this , can you send me a link to directly go to the page needed
thanks
Re: Need a PIN code to download
@ShorehamNick
Try this link:
https://www.sky.com/productsettings/tv/parental-controls
@ShorehamNick
Try this link:
This message was authored by: Supertramp1
This worked! Thanks
Avatar for ShorehamNick
Brilliant that worked a treat
can now download to iPad
thank you so much
This message was authored by: Kc40
Thank you so much!! I have tried for over an hour with various links in the site that do not work. Very much appreciate your time 🙂
This message was authored by: BenBrinkworth
Thank you for this post - is someone able to provide feedback to Sky that the advice and links from the app don't take you to this link and so it's impossible to fix unless you happen across this post.  Both the links in the mobile app and windows app take you to the same incorrect link:  www.sky.com/devicepin
This message was authored by: Dixiebelle
Watch sky cinema on iPad with sky glass
I have Sky glass and I can now watch Sky channels on my iPad but when I want to watch a film it says I need to use my pin! Thanks fine but it doesn't give me the opportunity to enter it! Any ideas please!
Re: Watch sky cinema on iPad with sky glass
What's the exact message it says, just so we're all on the same page?
I can download sky on my iPad but sky cinema I need my pin but there's nowhere to insert it! I have Sky glass
Try as it says there, click on the following link and check your parental controls;
@Dixiebelle
https://www.sky.com/help/articles/your-pin-sky-go
Have moved your post to the Sky Go  section and this similar thread as the answered post should answer the issue.
I can't get Sky go on Glass! After TV it goes to Sky Go Devices ... opens the screen with Mamage your Sky TV Devices then..
Device Name
Device Information
....no way to enter Parental Controls
thank you for any help!
Answered - Go to Answer
