Discussion topic: My MacBook will not register as a device in Sky Go
Message posted on 19 Oct 2024 01:14 PM
I downloaded a number of programmes recorded on my Sky Q box to my MacBook to watch whilst on holiday. When I tried to watch them on holiday I got a message that I needed to be connected to my Sky Q box (if I was at home, I wouldn't need to watch on my Mac).
I checked my devices and my Mac is not listed, although my iPad and iPhone are.
Since returning home I have attempted to authorise my Mac without success. Can anyone suggest a solution?
Message posted on 19 Oct 2024 01:26 PM
Re: My MacBook will not register as a device in Sky Go
Noe you are back in the UK what is happening when you go to watch live TV ?
Message posted on 19 Oct 2024 02:03 PM
Same problem here; macpro won't connect anymore to the sky q box. can't access the channels I'm paying for and can't access my recordings; Sky unable to help.
Message posted on 19 Oct 2024 05:38 PM
I can watch some channels, but only those that don't require a code. It won't accept my code and when I reset it, it still doesn't work.
Message posted on 19 Oct 2024 05:42 PM
My MacBook is still not included in my list of devices
Message posted on 19 Oct 2024 07:29 PM
Do you mean a pin, if the Sky Go app is not connected to a Sky Q box then the pin for it can be reset here:
https://www.sky.com/manage/tv/manage-devices/change-pin
Message posted on 20 Oct 2024 04:53 PM
Thanks for trying to help, I have already changed the PIN many times, but it isn't recognised when I enter it on my Mac in the Sky Go app.
Message posted on 20 Oct 2024 05:06 PM
Are you changing the pin in the correct place as it is quite easy to in error change the pin for a Sky Q box in error.
Message posted on 20 Oct 2024 05:15 PM
Yes, I'm changing it in the correct place, but it's still not recognised
