Discussion topic: I am unable to view my recordings on my iPad as it won’t find my sky q box
This message was authored by Gillby This message was authored by: Gillby
When I try to search for my recordings via the sky go app on my iPad, the iPad says it is unable to find any Sky Q box.
so points to note, yes I am connected to the same network as my sky Q box. My sky q box is switched on.
Sky go iPad settings does allow me to connect to networks.
Sky go app is up to date. But no matter what I try, my sky go app on my  iPad just won't connect to my sky box. I can still watch some of the live channels, box sets and on demand. But not my recordings.
Any advice is greatly appreciated.
Re: I am unable to view my recordings on my iPad as it won’t find my sky q box
Do you have a multiscreen subscription on your account, if you do have you tried a reboot of both your iPad and your Sky Q box ?
Gillby
@caesarome Yes I have multi-screen.
i have also rebooted both IPad and sky q box.
I've even deleted the sky go app and reinstalled it. No joy
This message was authored by king+samoo This message was authored by: king+samoo
Hi, I was having the same problem but I remembered that I was using VPN. When I turned it off it solved it found the sky q box again.
Gillby
@king+samoo thanks, yes I did turn off my vpn also.
I did install a new internet extender for when I'm upstairs. But it is a Tp Link one and is compatible with the tp li k router. So no different connection name or anything.
and even when downstairs next to the router it doesn't connect to sky q box ☹️
This message was authored by Frankdontgetit This message was authored by: Frankdontgetit
Hi,  I'm having the same problem as Gillby, there was a recordings tab at the bottom right of the App screen.
When selected the iPad would search for the Q box but never find it!
After deleting and reinstalling Sky Go the recordings tab is not there anymore!
This is really annoying me now, please help?
This message was authored by Eddiechell This message was authored by: Eddiechell
I deleted my sky q app then put on a new app recorded a program and it worked I got my recordings back
On average, new discussions are replied to by our users within 3.6 hours
