6
This discussion topic has been answered Discussion topic: External display output is blocked
This message was authored by: John+corless
This message was authored by: Annie+UK Answer
Re: External display output is blocked
This is normal for Sky Go on a mobile device, Sky only want the devices own screen to be used for output
If you are using the devices screen only then you might want to report this to [email protected]
This message was authored by: daveNOS
@John+corless That doesnt give anyone here much to go on, where are you seeing that message?
Avatar for John+corless
Hi sorry its on my mobile phone tried reinstalling it several times . It worked OK till recently.  I have changed my phone to a Samsung s10 recently
Are you using the Sky Go app, if not what app are you using ?
Yes skygo app deleted and reinstalled several times
Have you got your mobile connected to an external device, if not and the message has only just started have you recently installed any new apps on your phone that could be causing this ?
