This discussion topic has been answered Discussion topic: Error code 3-2 Sky Go won’t work
Message posted on 07 Mar 2023 02:57 PM
Any suggestions.? Sky Go sending message Error 3-2, suggests re onnecting to the internet, which I've do e. BBC iPlayer and ITV X working perfectly, so I cannot understand it.
Message posted on 07 Mar 2023 03:49 PM
Turn the Wi-Fi or data connection if in your device then delete the app and reboot your device. When it has loaded back up turn the Wi-Fi or data connection back on and install the app again.
Message posted on 07 Mar 2023 09:16 PM
Re: Error code 3-2 Sky Go won’t work
Thank you, that has do e the trick and it is now working perfectly!
Message posted on 18 Jun 2023 09:44 PM
I have done this and it made no difference. Sky go working fine on other devices but not on my A8 Tablet which has always worked up till now, was bought from Sky and has a Sky Mobile SIM in it...any other ideas?
Message posted on 08 Jul 2025 05:13 AM
Deleted Skygo app. Installed again and it worked! Thank you
