This discussion topic has been answered Discussion topic: Does Sky Go have a Mac OS Sonoma problem
Message posted on 15 Nov 2023 11:38 AM
Sky Go keeps buffering when watching some chanels, on other chanels it does it less freuquently than others, It was ok Intel Macs but a problem on Apple silicon Macs
Message posted on 15 Nov 2023 09:41 PM - last edited: 15 Nov 2023 09:45 PM
I have the occasional problem on my Mac Mini M1 but I use CleanMyMac and it seems clearing the caches makes it more stable. Also using the beta version helps. Also, Sky Go is not very efficient and uses a lot of resources (memory, CPU).
Sky Stream, Sky Glass, Philips 77OLED+950, Pioneer LX-901 7.1.4, EE 900 FTTP
Message posted on 16 Nov 2023 04:18 PM
Re: Does Sky Go have a Mac OS Sonoma problem
Not sure clean my Mac will help, it is a MacBook Pro 14 M2 pro with 16gb memory only a few months old, I think the issue is with sky go, you are right the app is resource hungry
Message posted on 22 Nov 2023 11:33 AM
I also have this problem and nothing I do seems to fix it, has anyone found a fix yet?
