Discussion topic: BBC not on Sky Go
This message was authored by: dabhughes
BBC not on Sky Go
Anybody know any BBC 1 & 2 aren't  on Sky go?
Re: BBC not on Sky Go
Hi @dabhughes   Because the BBC want you to use the BBC iPlayer.
@dabhughes
The only way to access the BBC channels via Sky Go is to connect the app to your Sky Q box, you can only do this if you have a multiscreen subscription.
@dabhughes
Those channels will appear if your Go client devices are on the same local network as your Sky Q box.  They won't be there for Go use away from home, when on cellular data or for Glass & Stream subscribers at all.
