5
This discussion topic has been answered Discussion topic: technical fault
This message was authored by: chumpsta
technical fault
technical fault on all TV channels??? broadband signal is fine... very frustrating 😕
Re: technical fault
@chumpsta
Have you removed and replaced the power supply cable so the set fully reboots?
Re: technical fault
It helps if you specify which television platform you are referring to.
Avatar for chumpsta
Level 0 icon
Re: technical fault
65 gen2 glass TV wifi
Re: technical fault
@chumpsta
Avatar for chumpsta
Level 0 icon
Re: technical fault
reboot worked... thankyou
Re: technical fault
@chumpsta
Always the first thing to try ; )
Glad it's OK now.
Answered - Go to Answer
