Discussion topic: Won’t keep power
This message was authored by: Craigp1978
Won’t keep power
Hiya the last few days my sky glass has had to be rebooted in order for it to turn on ... now it comes on with SKY for a few seconds then goes completely black it's not holding power! I've done everything possible now and it just won't turn on at all ! Please advise if possible
Re: Won’t keep power
@Craigp1978  I would give Sky a call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
This message was authored by: roger1949
Do what they say,insist on a replacement if it doesn't help
Avatar for Craigp1978
Thank you so much I will call them in the morning
