Discussion topic: Watching gave on sky (England) keeps on pausing is anyone else having the same problem
Message posted on 20 Jun 2024 06:23 PM
Keeps freezing sky glass?
Message posted on 20 Jun 2024 06:27 PM
Re: Watching gave on sky (England) keeps on pausing is anyone else having the same problem
@Jariley66 wrote:Keeps freezing sky glass?
Check your broadband - it's usually the cause of such freezing, or rather, the TV having trouble receiving a stable enough signal. Give your Glass a reboot (turn off at the wall for a minute or two) and see if that helps. You'll need to watch the footie by some other means whilst it does that as it's not a particularly speedy operation.
Message posted on 20 Jun 2024 07:09 PM
No issues here in HDR @Jariley66.
As @Padam_Padam indicates this could be a local issue to tour setup.
MikeAlanR
Message posted on 20 Jun 2024 10:12 PM
Thank you will try reboot of tv 👍
