7
This discussion topic has been answered Discussion topic: Wall mount
This message was authored by: Jo248
Wall mount
Does the sky glass gen 2 come with a wall mount?
Re: Wall mount
@Jo248
No: it's an optional extra which currently has to be purchased alongside the television set (either as a cash purchase or added to the finance agreement)
Re: Wall mount
@Jo248
This message was authored by: Inbro
Re: Wall mount
Been told from sky you can purchase a wall mount from Curry's for Glass 2
This message was authored by: Jporch316
Re: Wall mount
I've just checked their website but can't find one ?
Re: Wall mount
Try Amazon then
Re: Wall mount
@Inbro wrote:
Try Amazon then
Only sky stock them at the moment and only purchasable when making the initial order for a gen 2 glass. Fingers crossed this will change in the future.
worth noting the gen 1 and gen 2 are vesa compatible
Re: Wall mount
Sky did say the Glass tv 2  wall mount were universal and Curry's should have them but if your wanting the Sky glass 2. Wall mount that comes with the tv then purchase that from Sky with a new tv
Re: Wall mount
I think that means you can order a Glass television through Currys and add the Sky mount to the order: it's unlikely they'll keep separate stock in stores.
Alternatively they meant you can purchase generic VESA mounts there.
