This discussion topic has been answered Discussion topic: Wall mount
Message posted on 28 Feb 2025 04:47 PM
Does the sky glass gen 2 come with a wall mount?
Message posted on 28 Feb 2025 06:07 PM - last edited: 28 Feb 2025 06:15 PM
No: it's an optional extra which currently has to be purchased alongside the television set (either as a cash purchase or added to the finance agreement)
Message posted on 01 Mar 2025 12:54 PM
Re: Wall mount
Been told from sky you can purchase a wall mount from Curry's for Glass 2
Message posted on 01 Mar 2025 01:53 PM
Re: Wall mount
@Inbro wrote:Been told from sky you can purchase a wall mount from Curry's for Glass 2
I've just checked their website but can't find one ?
Message posted on 01 Mar 2025 02:31 PM
Re: Wall mount
Try Amazon then
Message posted on 01 Mar 2025 02:33 PM
Re: Wall mount
@Inbro wrote:Try Amazon then
Only sky stock them at the moment and only purchasable when making the initial order for a gen 2 glass. Fingers crossed this will change in the future.
worth noting the gen 1 and gen 2 are vesa compatible
Message posted on 01 Mar 2025 02:36 PM
Re: Wall mount
Sky did say the Glass tv 2 wall mount were universal and Curry's should have them but if your wanting the Sky glass 2. Wall mount that comes with the tv then purchase that from Sky with a new tv
Message posted on 01 Mar 2025 04:55 PM
Re: Wall mount
I think that means you can order a Glass television through Currys and add the Sky mount to the order: it's unlikely they'll keep separate stock in stores.
Alternatively they meant you can purchase generic VESA mounts there.
