Discussion topic: Voice control not working on my remote
This message was authored by: Bob791
Only 2 weeks in with Sky and the voice control on my remote has stopped working. Any ideas how to fix this please?
Re: Voice control not working on my remote
Hi @Bob791  welcome to the forum.  It could just be a software glitch so I suspect if you rebooted your Glass TV the voice commands on the remote may start working again.  To do this go to Settings > System Management > Resets & Updates > Restart device (do not do a factory reset).  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t panic when you first start the process.
Avatar for Bob791
Thank you
This message was authored by: Jporch316
@Bob791
This has worked for me in the past when I have lost voice control
Switch tv to standby (either with remote, or with button on side of set)
Switch off at plug
Switch on at plug (no waiting necessary)
When red standby light comes on, press Home button on remote.
