This discussion topic has been answered Discussion topic: Voice control has changed how it operates
Message posted on 27 Feb 2026 01:02 PM
Before today, my Glass TV (Air) would let me press the blue button on the remote and say e.g. "Sky News" and it would go directly to Sky News, no menus or further choices, just what I asked for. Today, if I say the same, it does a search and shows me options to select various things that have been on Sky News. Anyone else seeing this or can explain to me what has changed?
I have 2 pucks and they are working like the Glass used to.
Message posted on 28 Feb 2026 12:02 PM
@mikealanr Thanks. Your advice worked; however it is back to working as it used to so now simply saying "Sky News" goes straight to Sky News. The build and UI versions have not changed recently.
Message posted on 27 Feb 2026 11:11 PM
Re: Voice control has changed how it operates
Given we are fellow customers no one can give detailed updates but yes it's likely an update that has changed the behaviour. You can compare the UI version number and software version number of your glass and pucks. The easy way is to say "go to channel number xxx" so 501 for sky news.
MikeAlanR
