2
This discussion topic has been answered Discussion topic: Using Sky Q and Sky Glass concurrently
This message was authored by: DougP31
So I have Sky Q downstairs and multi room additional boxes in three rooms upstairs. My TV upstairs has broken and I'm wondering if it's easier to give back one of the multi room boxes and replace with a Sky Glass TV.
1. Is this possible?
2. Do I need to pay the Sky Glass subscription or can I just login in with my current Sky account and get all That I need from that?
This message was authored by: peter-marlow+1966 Answer
Re: Using Sky Q and Sky Glass concurrently
DougP31
You can't have both if you want a sky glass tv then you will have to replace all your sky q mini boxes and your sky q main box, if you have a broken tv then just buy a replacement, if you buy sky glass tv, you will need sky pucks to replace your q boxes and these are all connected ti the internet, you will need a new sky package to, also if you do go down the sky stream route then once you activate the sky glass tv/pucks you will have 30 days to return all sky q boxes, also bear in mind aswell that you will have 2 bills to pay on your next bill if you get sky stream, your last sky q bill and your first sky stream bill
P c marlow
@DougP31  No it's not possible you can either have sky Q or sky glass not both
DougP31
P c marlow
