Discussion topic: Telly problem
This message was authored by: Tellyproblem
Telly problem
When watching a program on live t v .the screen just goes black after about 10 mins
Avatar for Tellyproblem
Level 0 icon
Re: Telly problem
Will let you know in 10mins
This message was authored by: peter-marlow+1966
Re: Telly problem
Tellyproblem
Try unplugging the tv for about 10 mins, also what speed is the tv getting from your internet, you can find this out by opening netfix going to help opening that and running check my network, also if you can connect the tv to the hub with an ethier net cable it more stable than wifi
P c marlow
