Discussion topic: Technical issues
This message was authored by: Lpd37
Technical issues
Keeps saying there is a technical issue and programme waiting to load
Re: Technical issues
Hi @Lpd37 first thing have you tried a reboot?
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
