6
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: Cat34
Technical fault
Is anyone having a technical fault showing on their sky glass for every channel
This message was authored by: Angel_Aka Answer
Re: Technical fault
@Cat34 wrote:
Yes a few times
Try running a network check from the get help menu on the Glass TV's Netflix app. This will give you an idea of the broadband speed actually being received by the TV.
Re: Technical fault
@Cat34  How is your Glass TV conneted to your router?
Avatar for Cat34
Re: Technical fault
Hi through WiFi
Re: Technical fault
@Cat34 Have you tried a reboot a of your Glass TV and your router.
To reboot the TV:
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
To reboot your router just turn it off at the plug for a minute.
Avatar for Cat34
Re: Technical fault
Yes a few times
Re: Technical fault
@Cat34 wrote:
Yes a few times
Avatar for Cat34
Re: Technical fault
All sorted now thank you had to reset the whole TV and start from default 🙄
