Discussion topic: Technical fault
Message posted on 09 Jul 2026 03:17 PM
Technical fault
The sky tv does not work. This has happened past 2 days so no tv when u get in at night. And now not working during day due to a technical fault. Have unplugged everything and plugged back in but still same error
Message posted on 09 Jul 2026 03:28 PM
Re: Technical fault
@Rashmi2 wrote:The sky tv does not work. This has happened past 2 days so no tv when u get in at night. And now not working during day due to a technical fault. Have unplugged everything and plugged back in but still same error
Open Netflix on the Sky Glass, and run a network test by going to Get Help -> Check your Network and it will tell you the download speed the Glass is currently getting
