Discussion topic: Technical fault
This message was authored by: Rashmi2
Technical fault
The sky tv does not work. This has happened past 2 days so no tv when u get in at night. And now not working during day due to a technical fault.  Have unplugged everything and plugged back in but still same error
Re: Technical fault
Open Netflix on the Sky Glass, and run a network test by going to Get Help -> Check your Network and it will tell you the download speed the Glass is currently getting
