Discussion topic: Technical fault
This message was authored by: KatrinaS
Technical fault
Sky stream not working
Re: Technical fault
Hi @KatrinaS
We are fellow customers on the community. You will need to provide more information. Who is your ISP? Is your internet working ok? What broadband speed do you get? Has it been working previously? Etc.
However as a first point of call in would recommend restarting the puck (Settings > system management > resets and updates > restart).
MikeAlanR
