Discussion topic: Technical fault
Message posted on 16 Jan 2026 07:25 PM
Technical fault
Message posted on 16 Jan 2026 11:43 PM
Re: Technical fault
Hi @Leigh22
Try a reboot in the first instance. Failing this you will need to provide more information such as ISP, broadband speed, what speed is being report led in netflix (Profile pic > get help > connectivity check).
Remember we are fellow customers on the community not sky and know nothing about you unless you tell us.
MikeAlanR
Message posted on 17 Jan 2026 11:23 AM
Re: Technical fault
@Leigh22 wrote:
Sky glass. Programme loading.. Black screen
Same here this morning and absolutely nothing wrong with my Ethernet connections. Whisper it, "it's a Sky OS software issue".
One month to go 🥂
