Discussion topic: Sky tv technical fault
This message was authored by: Neil242
Message posted on 05 Feb 2026 11:24 AM
Every channel on sky tv shows on the shy guide but when selected comes up a technical fault try later
Find out more
Message posted on 05 Feb 2026 11:46 AM
Re: Sky tv technical fault
@Neil242 You've posted on the Sky Go board which is a PC/Mobile app.
You mention TV which platform is it? Sky Q or Sky Stream as this doesn't sounfd like an app relared issue
Message posted on 09 Feb 2026 02:36 AM
The fault is on sky glass and the puck on the other tv .
