Discussion topic: Sky stream still doesn’t work
This message was authored by: Stewpot80
Hi there I've tryed everything with the stream box but still not turning on now I want to cancel my sky stream as it's **bleep**e not working
Re: Sky stream still doesn’t work
You can't cancel via a public forum, you'll need to call Sky
This message was authored by: BRW1983
The issue with ours was that when it reset it wouldn't connect to WiFi, but there is a work around if you can connect the TV to  an Ethernet cable
Before going through the reset steps connect your TV or Puck to a Ethernet cable into your router, then go through the reset steps as Sky have set out
After the reset and update is done and you are on the Sky Home screen, you can disconnect the Ethernet cable and set the TV back up on the WiFi, I'm not sure if this will fix all TV/Puck not turning on issues, but it fixed both of our Sky Glass TV's (The one in the games room has not been working since December 2023, and is working fine (and on WiFi now)
I hope this information is helpful to some people who are still suffering with this issue
