2
This discussion topic has been answered Discussion topic: Sky pin
This message was authored by: Beet1985
Sky pin
Hi there where can I find my sky pin please
This message was authored by: Fothergill1 Answer
Re: Sky pin
@Beet1985  The default PIN is the last 4 digits of the phone number you have registered with Sky.  If you have changed it from the default the forum cannot help you.
Re: Sky pin
Re: Sky pin
@Beet1985 Try the last four digits of the mobile number registered on the sky account
