This discussion topic has been answered Discussion topic: Sky glass remote not working
Message posted on 06 Apr 2024 07:15 AM
The circle button on the remote is not working everything else on the remote is
Message posted on
06 Apr 2024
07:36 AM
- last edited:
04 Mar 2026
08:50 AM
by
KevNewMedia
Try a reset on the remote first
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
in the interim you can use a sky q remote to control the tv (if you have one)
Community Manager note: changed the link
Message posted on
06 Apr 2024
07:36 AM
- last edited:
04 Mar 2026
08:50 AM
by
KevNewMedia
Message posted on 05 Oct 2025 10:35 AM
Re: Sky glass remote not working
Can you use the tv at all with the sky glass remote not working
Message posted on 05 Oct 2025 10:43 AM
@JRoberts2 wrote:Can you use the tv at all with the sky glass remote not working
You can partially use it with voice commands
Message posted on 05 Oct 2025 02:40 PM - last edited: 05 Oct 2025 02:41 PM
Hi @JRoberts2 If you are lucky enough to have one in a drawer somewhere you can you the Sky Q remote in IR mode.
