Discussion topic: Sky glass cricket coverage not loading
This message was authored by: Colin67
Got up early today to watch cricket on Sky Glass. It constantly comes up with a message ' loading, please try later'. Not good! What is the problem ?
Re: Sky glass cricket coverage not loading
If you are connected via WiFi typically that's caused by the instability of the WiFi signal the Glass is getting. I had the same issue particularly streaming live sport, disabled WiFi in the settings, connected via Ethernet and gave it a reboot by unplugging for a few minutes and it should fix the issue.
