3
This discussion topic has been answered Discussion topic: Sky device pin
This message was authored by: Jjdaisy28
Sky device pin
I've forgot my sky device pin and just going round in circles when I try and get help
This message was authored by: Fothergill1 Answer
Re: Sky device pin
Hi @Jjdaisy28 I see you have already been provided with a useful link by @Anonymous but I'm not sure if it explains the following.
Like most people you will probably have changed the PIN but if not it should still be the default which is the last 4 numbers of the phone number you have registered with Sky.  This is applicable to both Sky Glass and Stream.
Re: Sky device pin
@Jjdaisy28  Which Sky device are you referring to?
Re: Sky device pin
@Jjdaisy28 Try the steps in this guide to see it helps:
https://www.sky.com/help/articles/your-pin
Re: Sky device pin
