Discussion topic: Sky cinema
This message was authored by: Gee2171
Sky cinema
Does anyone else have issues adding sky cinema? It isn't allowing me to add any subscriptions to my sky glass 🙃
Re: Sky cinema
@Gee2171  It's probably just a software glitch in which case a restart of your Glass will probably resolve the issue for you.  It's certainly worth a try.
To do this go to Settings > System Management > Resets & Updates > Restart device (do not do a factory reset).  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t worry when this happens as you start the process.
This message was authored by: Jporch316
Re: Sky cinema
Hi
try adding it via the MySky app on your mobile device or pc
