11
This discussion topic has been answered Discussion topic: Sky Glass viewing card.
This message was authored by: Dave2424
Does sky glass have a viewing card number?
This message was authored by: 82bit Answer
Re: Sky Glass viewing card.
Not possible. The only way to get TNT on Glass/Stream is through Sky. You can of course subscribe directly through TNT and use their app, but to view through the Sky EPG, you need a TNT subscription from Sky.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband [900/110]
Sky Mobile SIMO x7
No - there is no viewing card in Sky Glass or Sky Stream.
Avatar for Dave2424
I know there is no physical viewing card, I wanted to know if there is a viewing card number associated with Sky Glass, so I could get TNT Sport from BT, as it would be cheaper.
Sky Stream Puck x4
Sky Mobile SIMO x7
Avatar for Dave2424
Thanks 82bit,
It is crazy, because I've had TNT Sport on my Sky Glass via BT for a few years. Apparently, if you have it before you get Sky Glass, it transfers over, no problem, but you can't put it on after you've got Sky Glass. Obviously another way to squeeze more money out of us.
@Dave2424 wrote:
Thanks 82bit,
It is YOUR choice to be with Sky.
Avatar for Dave2424
Correct, it's MY choice.
I must say that reading the problems that others are having with Sky/Sky Glass, I must be very lucky.
@Dave2424 I don't think it is down to luck. The nature of a help forum like this one means that most people will be joining as they are experiencing issues and are looking for help and advice..  This gives the appearance that everyone has an issue.  The reality is that the majority of the millions of subscribers have a relatively trouble free experience.  I won't go as far as saying I never have issues but when I do they are generally minor and are resolved by a system reboot.  (I have no more issues than I had with Sky Q).
@Fothergill1 I very much doubt Sky have shifted 'millions' of Glass/Stream units. I would go as far as to say there's probably more Sky+ users than there are Stream.
Sky Stream Puck x4
Sky Mobile SIMO x7
This message was authored by: Jporch316
Nobody knows for sure as sky don't release any numbers ..... but im with @Fothergill1  on this one.
I agree - particularly if you consider worldwide as the puck is used in numerous Comcast subsidiaries worldwide including the US.
This message was authored by: Oscar803
Thank you for answering my querie regarding Skyglass air & if a veiwing card is needed
Answered - Go to Answer
