This discussion topic has been answered Discussion topic: Sky Glass remote volume mute.
Message posted on 22 Nov 2024 10:25 AM
Has anybody noticed that when they push the volume mute on the remote control, it doesn't actually mute the sound anymore? It just reduces it in volume a bit. This is only started happening this morning and anybody had any similar problems.?
Message posted on 25 Nov 2024 12:18 PM
I have managed to fix this!
I had exactly the same issue, it started a few days ago after I'd connected my bluetooth headphones for the first time?
I was able to fix it by pressing the the three dots button on the remote "..." top left. Then selected "Audio Output" and clicked on "TV Speakers", which was unticked for some reason, when I think it should be ticked by default?
Now works fine. Good luck.
(I'm on OS 1.3, Build version: QS033.014.00P. Remote control firmware: 5103.4.8)
Message posted on 22 Nov 2024 01:15 PM
Re: Sky Glass remote volume mute.
My Glass TV updated to QS033 overnight, and I now have the same problem, and more....
When turning the set on, the first channel I select has no sound until the volume is turned up or down. This can be from the guide, continue watching or the apps (Netflix, Amazon, etc.)
Mute moves the volume graphic to minimum, but the volume stays the same.
Reducing the volume to minimum mutes the sound.
Message posted on 22 Nov 2024 01:30 PM
Just to add, restarting the TV or unplugging for 30 minutes made no difference.
Message posted on 22 Nov 2024 01:37 PM
Sounds like another update has screwed up the system again. 🙄
Message posted on 23 Nov 2024 03:14 PM
Got the same issue.
Message posted on 25 Nov 2024 12:25 PM
Brilliant, that's fixed mine too.
Quite surprising though, as the only Bluetooth device I have connected is the TV remote!
Message posted on 25 Nov 2024 12:32 PM
Can you both try the fix as mentioned in post 6?
Message posted on 25 Nov 2024 09:26 PM
Ah ha , don't know how u managed it but great Scot , it works now ! I can mute with the mute button .
Message posted on 26 Nov 2024 01:15 PM
@Nobby6 you legend, sorted mine with your instructions. Thank you
Message posted on 26 Nov 2024 01:17 PM
You legend, fixed mine straight away with your instructions thank you
Message posted on 27 Nov 2024 09:11 PM
This worked for me.
Thanks!
Message posted on 27 Nov 2024 11:31 PM
I've had problems since update, with mute not working unless I cover IR end of remote, and occasionally when I press volume up, it keeps increasing on its own.
I have soundbar setup thro ARC.
Now SKY GLASS 65" +
3 Pucks
SONY S40R 5.1 surround sound bar
SKY VIP Diamond (20+ Years)
Message posted on 28 Nov 2024 07:36 AM
This solution (to Sky's created problem) seems only temporary? I've had to repeat this procedure for a third time already.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband [900/110]
Sky Mobile SIMO x7
Message posted on 28 Nov 2024 07:40 AM
Mines been fine since i fixed it, fingers crossed it stays that way. Do love the sky glass though
