Discussion topic: Sky Glass gen 2 universe remote control codes
This message was authored by: Colin192
I have a 65" sky glass gen 2 tv, I have a free sat plug into it but the default tv codes are not working to control the volume
is there a code for the sky glass tv?
The volume and power buttons work with my fire stick so there must be a code that works?
Avatar for Colin192
Re: Sky Glass gen 2 universe remote control codes
Ok thanks I will try that later
Will that work with the freesat remote?
Avatar for Colin192
I think my remote only takes 4 digit code
This message was authored by: Jporch316
@angela852black wrote:
Hello,
To control volume on your Sky Glass Gen 2 TV using a universal or third-party remote:
Switch your remote to IR mode (hold 4 + 6 for a few seconds).
Try pairing with the TV brand set to "Sky".
Use one of these common Sky Glass IR codes: LT043-f1-zzz, LT055-f2-zzz, or LT065-f3-zzz.
Best Regard,
Angela
those are not codes they are glass tv model numbers ......
@Colin192
ignore the previous post! - you would need to check if your freesat box can support the remote functions for a glass TV. You could try checking the fressat box manufactueres website or fourms for any relevant info.
