Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 20 Sep 2024 07:35 AM
Re: Sky glass tv won’t turn on I don’t have the red light
Both my Sky Stream pucks are not working. Both won't switch on and have a flashing white light. This started yesterday for me.
Sky puck isnt turning on
Sky puck isnt turning on for the last 15 hours still waiting for it too come on i thought it would be fixed and all this morning so my son could watch his cartoons please fix it soon my soon misses his cartoons 🙏
Message posted on 20 Sep 2024 07:36 AM
Re: Sky Puck & Sky Glass Power up issues 19-9-24
My sky Glass is still not working
Re: Sky Glass Power up Issues 19-9-24
Ours is still not powering on and doesn't have the red light on the front either. The day before our soundboard stopped working miraculously 2 months out of warranty and they want £624 to replace or set up a new credit agreement. Very strange that they can do this to so many of our TVs remotely. It sounds like the Apple iPhone Scandal where they purpose slow the device down in order for people to buy new devices.
Have the same issue
However
I have 2 pucks one on an old sharp TV and one on a LG TV
The sharp one works fine the LG one does not Yes I have tried
Turning it of and on did a hard reset which lets you do it all then all you get is sky logo in white and then No signal message
The strange thing is when I change the pucks over the one that worked on the sharo TV does now not work on the LG and the LG one now works on the Sharp
Foe good measure I have an LG tv in the kitchen a s well which is only 2 years old and guess what the pucks dont work on that one eirher
Has SKY had a software update in the last 2 days ?
Hope this helps
Message posted on 20 Sep 2024 07:37 AM
Stream reset - pin not working
Reset one of my stream boxes this morning to try and fix it and now I am stuck because it won't recognise my PIN. Typing the correct PIN in does nothing, just takes me back to attempt 0/3.
Help please!
Re: When will you fix the sky glass turning on problem.
No power light
Re: Sky stream won’t turn on - flashing white light then nada.
Also having this problem this morning.
Message posted on 20 Sep 2024 07:38 AM
Sky glass
My sky glass tv won't switch on
Mine is exactly the same went off last night and still not on this morning!!!!
Message posted on 20 Sep 2024 07:39 AM
Re: Sky glass tv won’t turn on just flashing red light
Mine started doing it last night and still not working this morning, tried everything listed with no luck.
Sky Glass not working at all
No sky glass service since tea time yesterday.
No indication when this will be resolved.
Poor service
Message posted on 20 Sep 2024 07:40 AM
Re: Stream puck won't turn on
I have been without sky glass since teatime yesterday, no updates on sky website to say when they expect the issue to be resolved.
