4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: Shakira1
Re: Not working
Good luck hopefully it start to work for you
Re: Sky Puck & Sky Glass Power up issues 19-9-24
Followed the instruvtions in the answer post
Both my pucks are up and running again.
This message was authored by: Northolt55
Re: Sky glass won’t turn on
Me to .... nothing
unplugging , nothing
This message was authored by: Jose66
OK I am up and running agian....
So many silly intructions passed on from sky....
SIMPLES solution.....  Turn off power --> turn on power -->  as you do hold button on Puck for at least 20 secs......lots of flashing colours --> system needs an update --> you will have to apply an activation code --->you will have to set up your fav channels again but all Playlists are saved.
GOOD LUCK AMIGOS
Re: I presume that I will not be charged for this service since Sky Glass is not functioning.
@Darminder1  Don't assume anything, there is no automatic right to compensation for loss of tv service you will need to discuss with sky
This message was authored by: Jocie22
All working now 👍🏻
This message was authored by: DTH1954
My Puck has stopped working, I cannot access any channels
When I switch my sky box (puck?) on, it flashes for a while then shuts down. Initially I get the Sky logo on screen but after a few seconds it shuts down.  This is a new piece of equipment only a couple of months old.
This message was authored by: Cozmicpurple
Re: I have a issue with my skyglass
Same here about 10 mins ago
This message was authored by: Dave451
My Sky Glass won’t turn on
My Sky Glass TV won't turn on.
This message was authored by: Hobbayne64
Re: Sky Glass Power up Issues 19-9-24
Well, I have tried unplugging it and leaving it for half an hour, plugging it back in again, holding the button for two minutes, but still completely dead. No red light, no nothing. This is terrible..
This message was authored by: sjw13
Re: Puck keeps flashing white light but won’t connect
@https://helpforum.sky.com/t5/user/viewprofilepage/user-id/19213
Turn off then back on & hold the button?
This message was authored by: PESKYWAABBIT
And have to manually log in to all your apps again I assume.
Hassle.
Same issue
Almost like no power going through tv at all ?
anyone else with issues that sky glass working in other areas of the house but not on main tv ?
This message was authored by: Maz6971
Re: Fixed it
Thank you! Just done this and got both my pucks working.
This message was authored by: AaronJames
Re: Sky Stream Puck stuck on PIN reset
I have the same issue with my puck, only had it a few days as a new Sky customer as well. Keeps going on pin reset then asks me to reset so I do and then gets me to confirm it, tells me the pin is wrong. Anyone know how to resolve this?
Locked
Answered - Go to Answer
