Discussion topic: Sky Glass - No Sound
This message was authored by: Ptims
Hi all,
Have a 2 year old Sky Glass TV. Sound has completely stopped functioning. Not an issue with the speaker as it won't even play when I connect Bluetooth. The TV itself has slowed right down and takes ages to load anything. Have done a hard reset but no joy. Any suggestions?
This message was authored by: Jporch316
Re: Sky Glass - No Sound
Is is over 2 years old or under ? If under a warranty still applies......
do you have sky protect cover ?
Avatar for Ptims
Out of warranty now, unfortunately. No cover either, seems like a software fault as no ones touched the tele.
Will a soundbar work if you plug it through hdmi 2 earc ?
Avatar for Ptims
I'll give it a try but nothing comes through on Bluetooth. Which makes me think its the TV. Cheers though
@Ptims wrote:
Hi all,
I'm assuming you've factory reset the tv ?
Avatar for Ptims
Yup, still no joy.
