Discussion topic: Sky Glass - No Sound
Message posted on 01 Aug 2025 11:50 PM
Hi all,
Have a 2 year old Sky Glass TV. Sound has completely stopped functioning. Not an issue with the speaker as it won't even play when I connect Bluetooth. The TV itself has slowed right down and takes ages to load anything. Have done a hard reset but no joy. Any suggestions?
Message posted on 02 Aug 2025 08:37 AM
Re: Sky Glass - No Sound
Is is over 2 years old or under ? If under a warranty still applies......
do you have sky protect cover ?
Message posted on 02 Aug 2025 12:02 PM
Out of warranty now, unfortunately. No cover either, seems like a software fault as no ones touched the tele.
Message posted on 02 Aug 2025 12:23 PM
Will a soundbar work if you plug it through hdmi 2 earc ?
Message posted on 02 Aug 2025 12:25 PM
I'll give it a try but nothing comes through on Bluetooth. Which makes me think its the TV. Cheers though
Message posted on 02 Aug 2025 01:34 PM
@Ptims wrote:Hi all,
I'm assuming you've factory reset the tv ?
Message posted on 25 Sep 2025 10:35 PM
Yup, still no joy.
