2
This discussion topic has been answered Discussion topic: Sky Glass Gen 2 55inch Picture Issues
This message was authored by: KJLav
Hi everyone,
A couple of weeks ago we moved from Sky Q to Sky Glass Gen 2. The picture is generally really good, however, over the last few days I have noticed a few issues.
1. Watching any kind of sport - when the camera pans across the screen it looks like there are feint dark vertical lines from top to bottom as it moves.
2. When watching TV in UHD, sometimes the screen flickers in parts. This is particularly noticeable on a light area (face) set against a dark background. The face area seems to flicker.
Once I've noticed both issues, it's quite hard to unsee.
We didn't have this issue at all with Sky Q and our Samsung TV. I'm just keen to know if this is an issue with the Sky Glass TV or just one of the issues with streaming as opposed to satellite.
Cheers
Kris
This message was authored by: BenJoBanjo Answer
Re: Sky Glass Gen 2 55inch Picture Issues
@KJLav
To answer your questions individually,
1. What you are seeing here is known as DSE or Dirty Screen Effect. It's symptomatic of many cheaper LED backlit LCD panel TVs whereby uneven backlighting can reveal the array of LED's behind the screen - these are the vertical lines you can see.
It's not uncommon in many LCD TV's but to varying degrees. Many people, when buying an expensive TV play the panel lottery (as it's known in AV circles) where they will keep returning a TV until they get a panel which is free of DSE. This can take a while and can be futile.
In the case of Sky Glass, there's not a lot you can do other than request a swap, which you should do sooner rather than later. You might, or might not get a better panel, that's the lottery you play with backlit LCD TVs.
Glass is a mass-produced TV so there are variances in quality. You're paying a lot of money for it but you should decide whether you think it's worth trying for a better replacement.
As you say, once you've seen it, you can't unsee it. It's part of the reason I moved to OLED from a backlit LCD - there is no DSE with OLED TV's due to every pixel being self-emitting - no backlight is necessary.
2. Flickering should not be happening. This again is down to poor backlighting and software decoding of the image, so it's the fault of the Glass TV and is nothing to do with streaming. You can try different picture modes and try changing the auto backlight setting to see if it improves but it really shouldn't be happening on any picture mode to be honest.
Basically, I'd recommend contacting Sky for further troubleshooting, but if you are not happy with the quality of the TV for the price you have paid you should insist on a replacement. If this doesn't improve matters you can always buy a different smart TV and switch to Sky Stream which gives the same Sky streaming experience as you get on Glass. There's an interesting article here which might be worth a read.
@KJLav
This message was authored by: SKEEJ
Its the bad backlight they have installed, even on a new sky glass the tv will only last a year. Its disgusting.
Answered - Go to Answer
