Discussion topic: Sky Glass Ethernet Connection
Message posted on 31 Dec 2023 06:07 AM
Morning,
I'm a complete novice at this, so I'm hoping an expert can help.
I recently had Sky Glass installed with a 43" Sky Glass TV, and a have two pucks connected to Samsung TVs upstairs.
They're all currently connected by WiFi, but the signals upstairs appear to be weaker, as at times the screen appears pixelated, and the response to pressing the remote control is delayed compared to the Sky Glass TV downstairs.
Will connecting the Sky Glass TV by ethernet cable improve things, and will improvement only be seen if I connect all three televisions by ethernet cable? Also, if I connect the pucks upstairs by ethernet, does the cable from the puck need to connect to my router downstairs, or the TVs they're used for, while still having an HDMI connection from the puck to the Samsung TVs?
Message posted on 31 Dec 2023 07:32 AM
Re: Sky Glass Ethernet Connection
Ethernet is better for longer distances from the router
one end in router other end in puck
if you have the means a good mesh WiFi system will negate the need for cables
Message posted on 31 Dec 2023 07:33 AM
Or the cheaper alternative is powerline adapters but these do fluctuate in usefulness depending on the electrical ring main setup in your property
Message posted on 31 Dec 2023 07:49 AM
Unless you are good at DIY running ethernet cables will be problematic, hence resorting to ethernet over power line becomes the answer.
How old is the house?
What is the construction of the house walls?
Message posted on 31 Dec 2023 07:58 AM
@Exiled-in-HH - I'm reluctant to use ethernet cables from the two upstairs pucks to the router downstairs, because I can't easily hide the wires and they'd look unsightly. I could however easily hide an ethernet cable from the router to the Sky TV downstairs. Did you mean resorting to power line over ethernet becomes the answer, or have I misunderstood? 🙂
The house is around 20 years old, external walls of brick, most internal walls are stud with plasterboard.
Message posted on 31 Dec 2023 08:07 AM - last edited: 31 Dec 2023 08:17 AM
No ... I did mean Ethernet over power line.
Your house's ring main should be good and young enough to support networking over power line🤔
Message posted on 31 Dec 2023 08:18 AM
Ah, okay, so maybe I do misunderstand. You said ethernet cable installation could be problematic if I'm no good at DIY (which I'm not), and that therefore ethernet would be the answer over power line. Why recommend ethernet over power line in this case? Sorry if I appear blunt, I see things in black and white and at times need a really clear answer:)
Message posted on 31 Dec 2023 08:22 AM
Ethernet over power line uses the house's ring main wiring😉
Message posted on 31 Dec 2023 11:28 AM
Basically you get a set of two powerline adapters (or more if necessary)
plug one in to a mains socket near the router and use a man ethernet cable between the adapter and the router
place the other adapter in a mains socket next to the device you want to use and run an Ethernet cable from this adapter to the device. Basically uses your mains wiring as "ethernet"
Message posted on 31 Dec 2023 02:10 PM
@Jporch316 , that makes perfect sense to me now. Thank you very much 😊
Message posted on 17 Oct 2024 01:32 PM
Jumping on this post! My sky router is in the front room, my glass TV is in the back room, if I run an Ethernet cable from the TV to a Deco mesh in the garden annex, will I get Wi-Fi to the TV in the garden so I can watch Netflix? Thank
