2
This discussion topic has been answered Discussion topic: Motion sensor
This message was authored by: Daniel691
Motion sensor
When I test it it dosent work
does it need to be on or off?
Daniel
This message was authored by: Fothergill1 Answer
Re: Motion sensor
@Daniel691 Yes it can be on or off, personally I turned all those options off as I found then annoying (we have 2 dogs who kept triggering it).
Go into Settings > Start up & Standby menu and you will find the various options. Whilst in that menu make sure that Networked Standby Mode is ON as this stops Glass losing the network when it goes into standby.
Re: Motion sensor
Avatar for Daniel691
Level 2 icon
Re: Motion sensor
Thank You @Fothergill1 @For Helping It Works Now!
Daniel
