Discussion topic: Sky Glass Blutooth connection issue
This message was authored by: KishorZingre
Hi there, I have an issue connecting my Sky Glass with Laptop via Bluetooth...
Re: Sky Glass Blutooth connection issue
@KishorZingre  Only headphones A2DP compatible can be linked via Bluetooth on glass nothing else
Avatar for KishorZingre
Level 0 icon
What a rubbish design that one can't connect aa basic as a laptop via Bluetooth!!!!
@KishorZingre I agree that Sky were remiss in not including a casting / mirroring option.  If you have a suitable third party device such as an Apple TV, Roku etc you can cast or mirror to Glass through that device.  I know you shouldn't have to go to these lengths but it is an option.
Presumably that was never part of the specification.  Glass really isn't intended to be a multipurpose smart television: it's bespoke hardware for the consumption of Sky subscription service.
