Discussion topic: Sky Glass Air Picture Issues
Message posted on 07 Mar 2026 03:58 PM
Recently had the Sky Glass Air 55 inch tv delivered on Saturday 28/02/2026 and the pic quality is not the greatest. I can see what I can only describe has shadows going down the screen. Will Sky change my tv. If needed as I'm in my 31 day period.
Message posted on 07 Mar 2026 10:59 PM
Re: Sky Glass Air Picture Issues
@alantooth1978 wrote:Recently had the Sky Glass Air 55 inch tv delivered on Saturday 28/02/2026 and the pic quality is not the greatest. I can see what I can only describe has shadows going down the screen. Will Sky change my tv. If needed as I'm in my 31 day period.
What you are seeing is known as DSE or Dirty Screen Effect. It's a symptom common in cheap backlit LCD TVs. You should absolutely get your TV swapped if you find the quality unacceptable. You might not get a better Glass Air though as they are all of the same spec & subject to a bit of a panel lottery. You might get a good one or you might not. It's the same with most cheap TVs.
