This discussion topic has been answered Discussion topic: Sky Glass 55” Wall Mount
Message posted on 23 Apr 2025 08:37 PM
Hi All
I'm currently in the process of moving home & I no longer have the original wall mounting plate for my 55" Sky Glass. I've contacted customer service who've advised they are unable to sell me one, I wondered if anyone on here has a spare I could purchase if they used there Sky Glass with the tv stand instead of wall mounting.
Thank you in advance!
Message posted on 23 Apr 2025 09:34 PM
I have added a photo of the wall mounting bracket at is already on the tv
Message posted on 23 Apr 2025 09:06 PM
Re: Sky Glass 55” Wall Mount
Glass is VERSA compatible so any mount will work. Just make sure that it is rated for the weight.
MikeAlanR
Message posted on 23 Apr 2025 09:31 PM
The sky gen one wall mount is part of the stand already , so if you have ot on it's stand then you already have a wall mount bracket for your tv
Message posted on 23 Apr 2025 09:33 PM
Hi Peter,
I've currently got the TV on a third party wall bracket as we needed the functionality to move the tv around, but I've misplaced the original wall mount & want it to fit flush
Message posted on 23 Apr 2025 09:36 PM
Try Ebay see if you can get one on there
Message posted on 23 Apr 2025 09:47 PM
@LloydBrayford Did you keep the original Glass TV stand? If so it shoulkd be part of that?
Message posted on 23 Apr 2025 09:48 PM
I did, but the plate isn't in the box.
Am I being stupid and I've already got the plate attached to the back of my tv? 🤣🤣
Message posted on 23 Apr 2025 09:50 PM - last edited: 23 Apr 2025 09:52 PM
@LloydBrayford If you're using a 3rd party bracket you won't be able to have the original flush mounting wall bracket attached at the same time.
You'd have to remove the stand, with the bracket attached to reveal the vesa mounting holes
