Discussion topic: Rewinding on Sky Glass/Stream
Message posted on 10 Sep 2024 05:05 PM
I am thinking of getting Sky Glass but have a question on rewinding within a program.
1) in Sky Q when rewinding you can visibly see how far you are going back (or forward) . Makes finding where you are very easy.
2) When watching TV via an App ( i.e netflix) all you get is a time line of how far you can move. This really is annoying as you have to second guess how far back you need to go.
I want to know if within Sky Glass or stream is it option 1 that is available or option 2?
Thanks in advance as this will have a big bearing on me moving to Glass.
Message posted on 10 Sep 2024 06:00 PM
Re: Rewinding on Sky Glass/Stream
@Safc19732 wrote:I am thinking of getting Sky Glass but have a question on rewinding within a program.
2) When watching TV via an App ( i.e netflix) all you get is a time line of how far you can move. This really is annoying as you have to second guess how far back you need to go.I want to know if within Sky Glass or stream is it option 1 that is available or option 2?
It depends on what you're watching and whether or not it's being played back via an app or not.
If watching a Sky programme on demand for example, you will get option 1 - a line which shows you where you are in the show and a dot which moves as you rewind/fast forward. Similar to Sky Q, but with a bit of added latency due to a stream being controlled, rather than a recording on a hard drive.
If watching something on demand via an app then you are at the mercy of that particular app's user interface. So a BBC show will play back via iPlayer, an ITV show via ITVX etc.
