Discussion topic: Replace my remote control
Message posted on 09 Apr 2026 04:53 PM
My remote has stopped working and we need a replacement
Message posted on 09 Apr 2026 04:55 PM
Re: Replace my remote control
Sky has a few remotes so what TV service do you have, Sky Q, Sky+, Sky Glass or Sky Stream ?
Message posted on 09 Apr 2026 04:56 PM
SKY glass
Message posted on 09 Apr 2026 05:09 PM
I have moved your post to the Sky Glass forum for an answer to this.
Message posted on 09 Apr 2026 05:37 PM
How can I get replacement tv control
Message posted on 09 Apr 2026 05:40 PM
@TinaBates wrote:How can I get replacement tv control
Depends on what's wrong with it. If it's faulty or randomly stopped working then Sky should replace it under warranty. If not then you'll need to buy one yourself:
https://www.sky.com/help/articles/damaged-or-lost-sky-glass-remote
Message posted on 09 Apr 2026 05:52 PM
Have you tried re pairing your remote control;
- Press and hold 7 and 9 together for 3 seconds.
- Press and hold 1 and 3 together for 3 seconds.
- Wait until you see the 'Your remote is now connected' message and select Continue.
More help info here;
At the end of this article, if you have tried all it asks, you can order a replacement remote control online from Sky or partner sites.
