Discussion topic: Remote control
Message posted on 19 Jun 2025 09:01 PM
Remote control
My remote control isn't working. I have tried all of the steps you have told me to do.
the voice bottom works but I can't press select up or down.
Message posted on 19 Jun 2025 09:04 PM
Re: Remote control
Hi @Sanchia
You are not talking to sky. We are fellow customers like yourself on the community.
If you are under warranty you can ask for replacement here: https://www.sky.com/help/forms/streaming-tv-remote
Or they are available to order on Amazon if not under warranty.
MikeAlanR
Message posted on 19 Jun 2025 09:07 PM
Re: Remote control
Have you tried the following
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
