6
This discussion topic has been answered Discussion topic: Question re Sky Glass and puck
This message was authored by: DBN
hi got the Sky Glass tv today with my Sky glass puck box. No instructions. its is working ok but does this litte box replace my old large sky box that is connected to the satellite dish? and why have i got 2 identical remotes, one with the tv and one with the puck box?
I haven't plugged in the old large sky box and its all working so seems to suggest its not needed?
This message was authored by: GD1 Answer
Re: Question re Sky Glass and puck
@DBN  Sky Glass & The Stream Puck replace Sky Q as you can't have 2 different subscription types on your account, youll need to return the Q box when Sky send you packaging, usually after the cool off period
Avatar for DBN
thank you. so the external satelite dish is no longer needed?
This message was authored by: Hunter2660
Nope not needed. Just a point though the Glass TV and the puck are seperate. You use the puck on a 2nd TV, not the Glass TV, ie bedroom. So two remotes are standard.
Avatar for DBN
i have it plugged into the glass tv . I dont have a 2nd one. So I dont actually need it? ta
In that case cancel Whole Home, I presume you have it, and save money.
Avatar for DBN
thank you! I didnt know this and have cancelled it
