Discussion topic: Programs not loading - Technical Fault
This message was authored by: Neil267
Sky Glass has just stopped working and put up the message :
program waiting to load then says Technical Fault.
This message was authored by: 82bit
Re: Programs not loading - Technical Fault
Pull the plug and restart it. Fixes most issues like this.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband
Sky Mobile SIMO x7
This message was authored by: wsimm
Oh lets see if its the same problem we had for the last 2 months that sky said is fixed....and locked the thread
