Discussion topic: Programme keeps going off saying please wait for your programme to upload there is a technical issue
This message was authored by: Niamh+w
Programme keeps clicking off whilst watching saying please wait for your programme to load there is a technical problem
This message was authored by: Jporch316
Re: Programme keeps going off saying please wait for your programme to upload there is a technical i
@Niamh+w
Current issue under investigation see thread below
https://helpforum.sky.com/t5/Sky-Glass-Live/Discussion-topic-There-is-a-technical-fault-Please-try-a...
@Niamh+w  Whilst Sky try to find a fix the only way I have found to get thing running as normal again is to reboot the Glass / Puck. Go to Settings > System Management > Resets & Updates > Restart device.  It takes a couple of minutes and you wiull have a blank screen for a while whilst it reboots.
