121
This discussion topic is read only This discussion topic has been answered Discussion topic: Discussion topic:There is a technical fault. Please try again later
Locked
This message was authored by: Dallybally
Re: Discussion topic:There is a technical fault. Please try again later
@Dallybally wrote:
Not had the lip sync issue before, watching the cricket, albeit on rewind live, it's about 5 seconds out, it's crazy. They'd better sort this out soon. So far that's all, it's showing in 4k fine picture wise, it's a new puck too.
A reboot sorted it, I can live with it for a bit, it's been good since I swapped 2 pucks out, overall more reliable than Q minis for me, which isn't saying much. At least the main Q box was rock solid and you could go to it when minis were playing up.
This message was authored by: RozJC
Glad to hear this is being looked into.
Just this evening I've had to reboot my puck three times to be able to watch TV or stream something different.
Hopefully this will get resolved soon.
Avatar for DJeff80
This message was authored by: DJeff80
I also love the ability of turning your tv off and then for maybe 10/20 seconds later you still get sound and not from the channel you left but from the channel you wanted to change to..
This message was authored by: SBurge
I have exactly the same problem and just keep restarting the box several times a day
The problem does not happen on the TV's where we stream from a Puck, so the issue is defintely with the Actual Sky Glass TV unit
I hope it will be fixed, as typically, our warrantly has just expired
Sharon
This message was authored by: nathangrimmer
Mine for the first time in weeks has been fine today.
Checked build version and ui numbers, no change to them so can't confirm there's been a update, unless it was a fault with sky backend stuff
This message was authored by: Janeandsteve
Is there any update yet as we are having the same problem and seriously thinking about asking you to take it back
This message was authored by: Gman1961
  • Same here, try to change channel and black screen. Pull plug on puck, wait several minutes for reboot and then it works for a while. The ability to change channels on a multi channel service is a fundamental function.
This message was authored by: Tony+Wilde
Same issue here for weeks, Gen1 updated to latest UI.  Constantly having to restart.. rewind and fast forward are very dodgy too ... same error message all the time sigh
This message was authored by: antonypg
Last week or so, random problems. Day before yesterday, my main box was next to useless, picture kept freezing, sometimes solid white picture, other times it kept losing sound.
Last night, perfect. Kept changing channels, no problems. So far today, perfect.
Fingers crossed they are updating something.
This message was authored by: ThomasStanley
Sky tv
Showing technical fault on screen, try again later
Re: Sky tv
@ThomasStanley
Which Sky TV platform do you have?
Re: Sky tv
Puck tv plays and stops says loading then technical fault. Wifi ok
Re: Sky tv
I'll move your post to the stream board @ThomasStanley
Re: Sky tv
@ThomasStanley
Have moved you post to this similar ongoing issue discussion thread.
A temporary workaround is to perform a settings restart or power reset.
See the answers post from Sky in this thread for the latest on the issue.
Re: More stream nonsense
Very annoying, having the same problem myself.
Locked
Answered - Go to Answer
