Discussion topic: Problem with remote
This message was authored by: Naomilouise
Problem with remote
Hi so I've got a sky glass tv but I've lost the remote i cant connect my tv to my internet or my phone im just wondering what I can do please if anyone can help me
This message was authored by: Jporch316
Re: Problem with remote
Hi @Naomilouise
 you can buy a new remote via this link
https://www.sky.com/help/articles/damaged-or-lost-sky-glass-remote
unfortunately there is no app for remote control available on mobiles .....
it's also possible to use an older sky Q remote if you have one lying around
Hi @Naomilouise in addition to the reply you have already received and a bit of a long shot but have you tried the command "Hello Sky Find my Remote"?  The remote should then beep fairly loudly to help you find it?
@Naomilouise
You can also turn the tv on at the side button and then use voice commands to navigate around the tv (inc playing live channels etc
